TD04H 19T chapitre 5.....
Re: TD04H 19T chapitre 5.....
Message non lupar Yul » Mar 5 Aoû 2014 21:09
Salut mon bonhomme!
J'ai trouvé ça, ça peut peut-être t’éclairer un brin:
According to HKS ratings:
7cm2 = A/R 0.50*
8cm2 = A/R 0.61*
10cm2 = A/R 0.73*
* = HKS rate theirs a little higher then others it seems, as others say:
7 cm2 = A/R 0.49
8 cm2 = A/R 0.57
10 cm2 = A/R 0.73
As for Pxx housings, the Apexi ratings are:
P13 = A/R 0.51
P16 = A/R 0.63
P18 = A/R 0.71
P20 = A/R 0.79
P22 = A/R 0.87
P25 = A/R 0.98
P27 = A/R 1.06
Bon, après ce ne sont que des données de certains préparateurs/fabricants (HKS et Apexi, pour ne pas les nommer) et il est probable que d'un stock de VF à l'autre, d'un fabricant à l'autre, on ait des variations!.. Aussi la comparaison entre les cm2 et les turbines Pxx... un 8 cm2 avec un A/R plus petit que celui d'une P16 8/ ...quoique...on parle d'AREA/Radius uniquement...
Peut-être à ne pas prendre pour argent comptant donc!
Lucky for everyone who doesn;t own or have access to all the Pxx housings, IHI have already gone to the trouble and even added the result to the name of the housing for convenience.
However, IHI's Pxx values are the mm2/mm, and because A/R is in in2/in you need to divide the mm2/mm value by 25.4 to get the correct A/R format.
So:
P13 = 13 / 25.4 = 0.511
P16 = 16 / 25.4 = 0.629
P20 = 20 / 25.4 = 0.787
P22 = 22 / 25.4 = 0.866
P25 = 25 / 25.4 = 0.984
P25 = 27 / 25.4 = 1.062
Remarque sur la fausse association de l'a/r et du flow max :
comment was only in reference to the A/R, not the actual flow of the housings mentioned - I should have worded it better, sorry for any confusion.
A/R should not be confused with the actual flow abilty of a housing. A physically larger housing will always flow more then a smaller housing with the same A/R.
I can confirm a 8cm is physically bigger than an IHI P20 from lying both side by side and comparing
Je te fais part de mes trouvailles sur ces dimensions! (c'est vrai qu'on sait quelle est plus grande ou plus petite mais pas réellement la taille de chacune, ...et là encore je ne parle que des turbines, bandes de gros malins! :frime: )
T'chuss l'ami!
Yul
En ligne: 25d 19h 27s
Message non lupar BruChoupi » Mar 5 Aoû 2014 22:36
Bonsoir Julien,
Mon dieu..............mes aspirines lol lol............
Je vais essayer de comprendre tout ceci demain.......au taf :mrgreen:
Merci@toi
Message non lupar BruChoupi » Mer 6 Aoû 2014 13:37
Question : différence entre 14412AA291 et 14411AA291 sur un VF28 ????????????????????
regarder :
VF28 14412AA291
ET 14411AA291 de chez RAimport ;)
Après vous auriez dit " Bruno, ce sont tes yeux.......va dormir un peu !!! " :mdr3: :mdr1:
Message non lupar Wattman » Mer 6 Aoû 2014 14:38
La différence c'est le pays de destination du turbo, comme souvent chez Sub. ;)
Message non lupar BruChoupi » Mer 6 Aoû 2014 14:49
Wattman a écrit:La différence c'est le pays de destination du turbo, comme souvent chez Sub. ;)
Bonjour Jean-Mi :langue3:
C'est aussi con que ça ??????????
Je pensais à l'histoire RA ou pas ???????????? Palier ou Roulements ??????????
Je ne suis toujours pas sorti de cette merde :pleur4:
PS : au juste ils ont quoi de plus les Types "RA" ???????????
Message non lupar Mric » Mer 6 Aoû 2014 21:13
type RA?
les sub ont des finitions RA équipement différent du modèle de serie
un vf28 est sur roulements et c'est tout
si sur palier c"est un vf29
Message non lupar BruChoupi » Mer 6 Aoû 2014 22:26
Mric a écrit:type RA?
Bonsoir Mric,
Clair et Net, comme J'aime !!
Message non lupar BruChoupi » Jeu 7 Aoû 2014 00:50
Bonjour les gars :hello:
Question ......une membrane percée de wastegate, quels Problèmes cela entrainent-il sur le turbo où sur la gestion de l'ECU avec une 3 voies Grimmspeed ????
Message non lupar Wattman » Jeu 7 Aoû 2014 12:58
Difficulté voire impossibilité d'atteindre la pression cible.
Message non lupar BruChoupi » Jeu 7 Aoû 2014 13:13
Bonjour Jean-Mi,
Ok, reçu !
Mais pas de casses possibles à cause d'une membrane percée alors !!
Message non lupar Mric » Jeu 7 Aoû 2014 19:52
non aucune
juste une caisse qui se traine la nouille
Message non lupar BruChoupi » Jeu 7 Aoû 2014 20:22
:mdr1: :mdr3:
Message non lupar BruChoupi » Ven 8 Aoû 2014 08:11
Bonjour les gars,
j'attends le RIB de Laurent, mais ça devrait se terminer par ceci :
Voilà, voilà..........
Message non lupar mike91 » Ven 8 Aoû 2014 11:35
Hello Bruno,
Il a l'air oval le tuyau pour la dump au niveau de l'échangeur, ou c'est mes yeux???
Message non lupar BruChoupi » Ven 8 Aoû 2014 11:51
Bonjour Mike :langue3:
Ben écoute............j'avais vu..........illusion optique souhaitable :(
760€ la rigolade................. :rougefaché:
+ ma wastegate Forge que je vais devoir peu etre changer ou adapter.............putain, tu parles d'une histoire qui devait au départ etre plug&play....
@bientôt mon Pote,
Message non lupar mike91 » Ven 8 Aoû 2014 16:46
Tu crois que tu vas en voir le bout??????
Message non lupar franck » Ven 8 Aoû 2014 16:51
j'ai vendue mon VF48 qui a 69000km a 500 euro a un ami
sinon je te l'aurais proposer ;)
remap by franck 450+
franck
En ligne: 43d 8h 40m 37s
Message non lupar Mric » Ven 8 Aoû 2014 18:36
tu as regardé chez japperformanceparts aux uk??
sur les boites il est 25% moins cher que Ra import
Message non lupar mike91 » Ven 8 Aoû 2014 21:04
Bizarre cette photo, non???
http://www.japperformanceparts.co.uk/part_details.asp?ID=152
Désolé pour les balises mais là j'suis sur la tablette...
Message non lupar Daigoroh » Ven 8 Aoû 2014 21:08
Tiens oui, c'est la même :-/
Retourner vers Turbo
