[Technique] Code erreur Subaru
Message non lupar Manu 1er » Jeu 29 Nov 2012 18:24
Prendre les codes erreur sur les vieilleries :mrgreen:
Contact, moteur arrêter :
Brancher les 2 fiches noir, ainsi que les 2 fiches verte situées sous le volant sous le volant .
Le check engine va se mettre à clignoter, clignotement long (les dizaines), clignotement court (les unités) .
Plusieurs défaut peut être indiqué l'un après l'autre, et le tout passe en boucle indéfiniment .
Voici la liste de ces codes erreur:
[align=center]1988 and later models with Multi-Point Fuel Injection (including Legacy)[/align]
11 Crank angle sensor or circuit
12 Starter switch or circuit
13 Cam position sensor or circuit (TDC sensor on Justy)
14 Fuel injector no. 1 (Legacy, Impreza, Justy, SVX); Fuel injector 1 and 2 (XT, Loyale, GL, DL)
15 Fuel injector no. 2 (Legacy, Impreza, Justy, SVX); Fuel injector 3 and 4 (Loyale, GL, DL); Fuel injector 5 and 6 (XT6)
16 Fuel injector no. 3 (Legacy, Impreza, Justy, SVX); Fuel injector 3 and 4 (XT)
17 Fuel injector no. 4 (Legacy, Impreza, SVX); Fuel injector 1 and 2 (XT6)
18 Fuel injector no. 5 (SVX)
19 Fuel injector no. 6 (SVX)
21 Coolant temperature sensor or circuit
22 Knock sensor or circuit (right side on SVX)
23 Air flow meter or circuit (exc. Justy); Pressure sensor (Justy)
24 Air control valve or circuit (exc. Justy); Idle speed control solenoid valve (Justy)
25 Fuel Injector 3 and 4 (XT6)
26 Air temperature sensor (Justy)
28 Knock sensor no. 2 (SVX, left side)
29 Crank angle sensor (SVX, no. 2)
31 Throttle position sensor or circuit
32 Oxygen sensor or circuit (no. 1, right side on SVX)
33 Vehicle speed sensor (VSS) or circuit
34 EGR solenoid valve
35 Canister purge solenoid or circuit
36 Air suction solenoid valve (Impreza); Igniter circuit (Justy)
37 Oxygen sensor (no. 2, left side , SVX)
38 Engine torque control (SVX)
41 Air/fuel adaptive control
42 Idle switch or circuit
43 Throttle switch (Justy)
44 Wastegate duty solenoid (turbo)
45 Pressure duty solenoid (turbo)/atmospheric pressure sensor circuit (non-turbo)
49 Airflow sensor
51 Neutral switch (manual transmission)/inhibitor switch (automatic transmission)
52 Parking brake switch (exc. Justy)/Clutch switch (Justy)
55 EGR temperature sensor
56 EGR system
61 Parking brake switch (Loyale)/Fuel tank pressure control solenoid valve (Impreza)
62 Fuel temperature sensor (Impreza)/Electric load signal (Justy)
63 Fuel tank pressure sensor (Impreza)/Blower fan switch (Justy)
65 Vacuum pressure sensor
Re: Code erreur Subaru
Message non lupar Manu 1er » Jeu 29 Nov 2012 18:41
[align=center]Subaru OBD2 Codes[/align]
P0031 Front oxygen (A/F) sensor heater circuit low input
P0032 Front oxygen (A/F) sensor heater circuit high input
P0037 Rear oxygen sensor heater circuit malfunction
P0038 Rear oxygen sensor heater circuit high input
P0065 Air assist injector solenoid valve malfunction
P0066 Air assist injector solenoid valve circuit low input
P0067 Air assist injector solenoid valve circuit high input
P0100 Mass Air Flow Sensor Circuit Malfunction
P0101 Mass Air Flow Sensor Circuit Range Problem
P0102 Mass Air Flow Sensor Circuit Low Input
PO103 Mass Air Flow Sensor Circuit High Input
P0105 Pressure Sensor Circuit Malfunction
P0106 Pressure Sensor Circuit Range Problem
PO107 Pressure Sensor Circuit Low Input
PO108 Pressure Sensor Circuit High Input
P0111 Intake air temperature sensor circuit range/performance problem
P0112 Intake air temperature sensor circuit low input
P0113 Intake air temperature sensor circuit high input
P0115 Engine Coolant Temperature Sensor Circuit
P0116 Engine Coolant Temp Sensor Circuit Low Input
PO117 Engine Coolant Temp Sensor Circuit Low Input
PO118 Engine Coolant Temp Sensor Circuit High Input
P0120 Throttle Position Sensor Circuit Malfunction
P0121 Throttle Position Sensor Circuit Range Problem
PO122 Throttle Position Sensor Circuit Range Problem
PO123 Throttle Position Sensor Circuit High Input
P0125 Insufficient Coolant Temperature for Closed Loop
P0128 Thermostat malfunction
P0130 Front Oxygen Sensor Circuit Malfunction
P0131 Front oxygen (A/F) sensor circuit range/performance problem (low input)
P0132 Front oxygen (A/F) sensor circuit range/performance problem (high input)
P0133 Front Oxygen Sensor Circuit Slow Response
P0135 Front Oxygen Sensor Heater Circuit Malfunction
P0136 Rear Oxygen Sensor Circuit Malfunction
P0139 Rear Oxygen Sensor Circuit Slow Response
P0141 Rear Oxygen Sensor Heater Circuit Malfunction
P0170 Fuel Trim Malfunction
P0171 Fuel trim malfunction (A/F too lean)
P0172 Fuel trim malfunction (A/F too rich)
PO181 Fuel Temperature Sensor A Range Problem
PO182 Fuel Temperature Sensor A Circuit Low Input
PO183 Fuel Temperature Sensor A Circuit High Input
P0201 Fuel Injector Circuit Malfunction - #1
P0202 Fuel Injector Circuit Malfunction - #2
P0203 Fuel Injector Circuit Malfunction - #3
P0204 Fuel Injector Circuit Malfunction - #4
P0244 Wastegate control solenoid valve malfunction (high input)
P0245 Wastegate control solenoid valve circuit low input
P0246 Wastegate control solenoid valve circuit high input
PO261 Fuel Injector Circuit Low Input - #1
PO262 Fuel Injector Circuit High Input - #1
PO264 Fuel Injector Circuit Low Input - #2
PO265 Fuel Injector Circuit High Input - #2
PO267 Fuel Injector Circuit Low Input - #3
PO268 Fuel Injector Circuit High Input - #3
PO270 Fuel Injector Circuit Low Input - #4
PO271 Fuel Injector Circuit High Input - #4
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0304 Cylinder 4 Misfire Detected
P0325 Knock Sensor Circuit Malfunction
P0327 Knock sensor circuit low input
P0328 Knock sensor circuit high input
P0335 Crankshaft Position Sensor Circuit Malfunction
PO336 Crankshaft Position Sensor Circuit Range Problem
P0340 Camshaft Position Sensor Circuit Malfunction
PO341 Camshaft Position Sensor Circuit Range Problem
P0400 Exhaust Gas Recirculation Flow Malfunction
P0403 Exhaust Gas Recirculation Circuit Malfunction
PO420 Catalyst System Efficiency Below Threshold
PO440 Evaporative Emission Control System Malfunction
P0441 Evap System Incorrect Purge Flow
P0442 Evaporative emission control system malfunction
P0443 Evap System Purge Control Valve Circuit
PO443 EVAP System Purge Control Valve Circuit Low Input
P0444 Evaporative emission control system purge control valve circuit low input
P0445 Evaporative emission control system purge control valve circuit high input
PO446 EVAP System Vent Control Low Input
P0447 Evaporative emission control system vent control low input
P0448 Evaporative emission control system vent control high input
PO451 EVAP Pressure Sensor Range Problem
PO452 EVAP Pressure Sensor Low Input
PO453 EVAP Pressure Sensor High Input
P0456 Evaporative emission control system malfunction
PO461 Fuel Level Sensor Circuit Range/Performance Problem
PO462 Fuel Level Sensor Circuit Low Input
PO463 Fuel Level Sensor Circuit High Input
P0464 Fuel level sensor intermittent input
P0480 Cooling Fan Relay 1 Circuit Low Input
P0483 Cooling Fan Function Problem
P0500 Vehicle Speed Sensor Malfunction
P0505 Idle Control System Malfunction
P0506 Idle Control System RPM Lower Than Expected
P0507 Idle Control System RPM Higher Than Expected
P0509 Idle control system circuit high input
P0512 Starter switch circuit high input
P0545 Exhaust gas temperature sensor circuit low input
P0546 Exhaust gas temperature sensor circuit high input
P0600 Serial Communication Link Malfunction
P0601 Internal Control Module Memory Checksum Error
P0604 Internal control module memory check sum error
P0703 Brake Switch Input Malfunction
P0705 Transmission Range Sensor Circuit Malfunction
P0710 Transmission Fluid Temperature Sensor Circuit
P0715 Torque Converter Turbine Speed Sensor Circuit Malfunction
P0720 Output Speed Sensor Circuit Malfunction
P0725 Engine Speed Input Circuit Malfunction
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0740 Torque Converter Clutch System Malfunction
P0741 Torque converter clutch system malfunction
P0743 Torque Converter Clutch System Electrical
P0748 Pressure Control Solenoid Electrical
P0753 Shift Solenoid A Electrical
P0758 Shift Solenoid B Electrical
P0760 Shift Solenoid C Malfunction
P0763 Shift Solenoid C Electrical
P0778 2-4 brake pressure control solenoid valve (2-4 brake duty solenoid) circuit malfunction
P0785 2-4 brake timing control solenoid valve (2-4 brake timing solenoid) circuit malfunction
P1086 Tumble generator valve #2 (LH) position sensor circuit low input
P1087 Tumble generator valve #2 (LH) position sensor circuit high input
P1088 Tumble generator valve #1 (RH) position sensor circuit low input
P1089 Tumble generator valve #1 (RH) position sensor circuit high input
P1090 Tumble generator valve #1 (RH) malfunction (stuck open)
P1091 Tumble generator valve #1 (RH) malfunction (stuck close)
P1092 Tumble generator valve #2 (LH) malfunction (stuck open)
P1093 Tumble generator valve #2 (LH) malfunction (stuck close)
P1094 Tumble generator valve circuit #1 (open circuit)
P1095 Tumble generator valve circuit #1 (over current)
P1096 Tumble generator valve circuit #2 (open circuit)
P1097 Tumble generator valve circuit #2 (over current)
P1100 Starter Switch Circuit Malfunction
P1101 Neutral Position Switch Circuit High Input (A/T)
P1101 Neutral Position Switch Circuit Malfunction (M/T)
P1102 Pressure Sources Solenoid Valve Circuit Malfunction
P1103 Pressure Sources Switching Solenoid Valve Circuit
P1104 Engine Torque Control Signal Circuit Malfunction
P1106 Engine Torque Control Signal 2 Circuit Malfunction
P1110 Atmospheric pressure sensor low input
P1111 Atmospheric pressure sensor high input
P1112 Atmospheric pressure sensor range/performance problem
P1115 Engine Torque Control Cut Signal Circuit High Input
P1116 Engine Torque Control Cut Signal Circuit Low Input
P1120 Starter Switch High Input
P1121 Neutral Position Switch Circuit High Input [MT Vehicles]
P1121 Neutral Position Switch Circuit Low Input [AT Vehicles]
P1122 Pressure Sources Switching Valve Circuit High Input
P1124 TCS Signal Circuit High Input
P1130 Front oxygen sensor circuit malfunction (open circuit)
P1131 Front oxygen sensor circuit malfunction (short circuit)
P1134 Front oxygen (A/F) sensor microcomputer problem
P1137 Front oxygen (A/F) sensor circuit range/performance problem
P1139 Front oxygen (A/F) sensor #1 heater circuit performance/range problem
P1141 Mass Air Flow Sensor Circuit High Input
P1142 Mass Air Flow Sensor Circuit Low Input
P1143 Pressure Sensor Circuit Low Input
P1144 Pressure Sensor Circuit High Input
P1146 Pressure sensor circuit range/performance problem (high input)
P1150 Front Oxygen Sensor Heater Circuit High Input
P1151 Rear Oxygen Sensor Heater Circuit High Input
P1230 Fuel pump control unit malfunction
P1244 Wastegate control solenoid valve malfunction (low input)
P1245 Wastegate control solenoid valve malfunction (fail-safe)
P1301 Fire due to increased exhaust temperature
P1312 Exhaust temperature sensor malfunction
P1325 Knock Sensor Circuit Low Input
P1400 Fuel Tank Pressure Control Solenoid Low Input
P1420 Fuel Tank Pressure Control Solenoid High Input
P1421 Exhaust Gas Recirculation Circuit High Input
P1422 EVAP Purge Control Valve Circuit High Input
P1423 EVAP Vent Control High Input
P1440 Fuel Tank Pressure Control System Low Input
P1441 Fuel Tank Pressure Control System High Input
P1442 Fuel Level Sensor Circuit Range/Perf
P1443 EVAP Control System Vent Control Function Problem
P1480 Cooling fan relay 1 circuit high input
P1500 Radiator Fan Relay 1 Circuit Malfunction
P1501 Idle Control System Malfunction (Fail Safe)
P1502 Radiator Fan Function Problem
P1507 Idle Control System Malfunction (Fail Safe)
P1510 Idle Air Control Solenoid Signal 1 Circuit Low Input
P1511 Idle Air Control Solenoid Signal 1 Circuit High Input
P1512 Idle Air Control Solenoid Signal 2 Circuit Low Input
P1513 Idle Air Control Solenoid Signal 2 Circuit High Input
P1514 Idle Air Control Solenoid Signal 3 Circuit Low Input
P1515 Idle Air Control Solenoid Signal 3 Circuit High Input
P1516 Idle Air Control Solenoid Signal 4 Circuit Low Input
P1517 Idle Air Control Solenoid Signal 4 Circuit High Input
P1518 Starter switch circuit low input
P1520 Radiator Fan Relay 1 Circuit High Input
P1540 Vehicle Speed Sensor Malfunction 2
P1544 High exhaust temperature detected
P1560 Back-Up Voltage Circuit Malfunction
P1590 Neutral position switch circuit high input
P1591 Neutral position switch circuit low input
P1592 Neutral position switch circuit (MT model)
P1594 Automatic transmission diagnosis input signal circuit malfunction
P1595 Automatic transmission diagnosis input signal circuit low input
P1596 Automatic transmission diagnosis input signal circuit high input
P1698 Engine torque control cut signal circuit low input
P1699 Engine torque control cut signal circuit high input
P1700 Throttle Position Sensor Circuit Malfunction (A/T)
P1701 Cruise Control Set Signal Circuit Malfunction (A/T)
P1702 Auto Trans Diagnosis Input Signal Circuit
P1703 Low clutch timing control solenoid valve circuit malfunction
P1704 2-4 Brake Timing Solenoid Valve Circuit Malfunction
P1705 2-4 Brake Pressure Solenoid Valve (Solenoid D) Circuit
P1711 Engine torque control signal 1 circuit malfunction
P1712 Engine torque control signal 2 circuit malfunction
P1722 Auto Trans Diagnosis Input Signal High Input
P1742 Auto Trans Diagnosis Input Signal Malfunction
Message non lupar Manu 1er » Jeu 29 Nov 2012 18:42
Message non lupar Wattman » Jeu 29 Nov 2012 18:42
Merci Manu!! Je post-it!!
Petite précision, brancher les cosses vertes n'est pas indispensable, ça marche avec uniquement les noires.
Message non lupar Manu 1er » Jeu 29 Nov 2012 18:44
Les verte serve à faire un auto diagnostique il me semble !
Normalement tu entends les ventilos se mettre en route, la pompe essence se mettre en route, etc ! ;-)
Re: [Technique] Code erreur Subaru
Message non lupar Wattman » Jeu 29 Nov 2012 18:47
Oui tout à fait, mais sans les brancher, on a quand même le clignotement du CE, c'est ce que je voulais dire.
Message non lupar Manu 1er » Jeu 29 Nov 2012 18:49
Message non lupar dark_micka » Jeu 29 Nov 2012 20:38
Petite precision.
Fonctionne sur vieilleries, tracteurs et betaillieres :mrgreen:
Sent from my HTC Vision using Tapatalk 2
Message non lupar Baron Gris » Jeu 29 Nov 2012 21:22
Message non lupar yostone » Ven 30 Nov 2012 11:30
Merci pour l'info :super:
Message non lupar RedZone » Ven 30 Nov 2012 15:36
Hello
Les cosses verte et noir ensemble c'est pour le reset, la lecture juste les cosses noir ;)
La procédure pour le reset:
-Moteur chaud
-Cosses vertes et noires branché
-Contact mis
-Pédale au plancher pendant 15s pour GT <2000 puis relâché
-Roulez calmement au dessus de 11km/h jusque a que le CE flash régulièrement, si problème toujours présent il reflash les codes
-Contact coupé
-Débrancher les cosses
Ps:
La désignation des codes OBD2 sont commun a toutes les voitures sous ce protocole ;)
RedZone
Pro
En ligne: 23d 15h 51m 28s
Ma voiture: GT 98
Couleur: 74F
Message non lupar Manu 1er » Ven 30 Nov 2012 21:20
C'est possible de rouler en dessous de 11 km/h :happy1:
Merci pour la précision Pierrot :merci:
Message non lupar lionos » Ven 30 Nov 2012 22:05
Bien utile pour quand la vieille fait des caprices, je touche du bois, je n'ai pas encore vu le CE s'allumer :gene:
Message non lupar Manu 1er » Ven 30 Nov 2012 22:08
Les vieilles sont moins capricieuses que les jeunes, tout à fait normal :mrgreen:
Message non lupar lionos » Ven 30 Nov 2012 22:09
Elles n'ont plus l'age pour toutes ses gamineries :mrgreen:
Message non lupar plaly » Lun 25 Mar 2013 23:44
Pour gt 2000 il y a un autre moyen d'avoir les codes défauts ou bien c'est passage à la balise obligatoirement? :cote:
plaly
En ligne: 1d 12h 43m 43s
Message non lupar stef » Lun 25 Mar 2013 23:47
plaly a écrit:Pour gt 2000 il y a un autre moyen d'avoir les codes défauts ou bien c'est passage à la balise obligatoirement? :cote:
t'en fais une belle de VALISE pas BALISE :hehe:
regarde le premier message de ce post , à quel moment parle t'il de VALISE ? ah oui viellerie ça veut dire gt,forester sf5,...
Message non lupar plaly » Mar 26 Mar 2013 00:13
Oui valise pas balise :hehe: Mon doigt a glissé sur la touche d'a côté hihiiii"""
Ou vais relire tous ça alors :rouge:
plaly
Message non lupar Manu 1er » Mar 26 Mar 2013 00:16
Cette méthode est valable sur GT2000, Alex ;-)
Et c'est valise, pas balise :hehe:
Message non lupar plaly » Mar 26 Mar 2013 00:43
Oui Mr :gene3: vais test si j'y arrive demain histoire de voir ce que ça dit, on ne sais jamais, peut être que mon soucis vas ressortir :]
plaly
